Change Text Color using Case
I have a small calculation, using case obviously, that tells the user whether the project is on time, due today, or past due. I need to know if I can write a small calculation that changes the text color like if the text in the field = past due. Thanks again.
j
What I have done in the past is used to calculated fields, one overlaying the other. Field one is formatted as black text for instance and the formula displays a result >=0 only. Field two is formatted as red and the formula displays a result <0 only.
That's a nice cheap work group. I guess it'll have to do to get the job done. Thanx for the work around!
j
