resuming a script help
Here is the problem: I perform a find and then the script pauses. I would like it to continue. The trick is that the perform find is in a portal.
Script:
Find Mode
"The Portal opens with some fields and a button(the button = Perform FIND)"
GO TO Layout
PRINT
GO TO Layout
The pause happens after the button is pushed. In the toggle window, a continue or cancel button shows. How can I get the script to continue without any interaction from the user?
Thanks in advance
Allow User Abort (off)
Set Error Capture (on)
Enter Find Mode (pause)
Goto Layout
Print()
Goto Layout
Set the button to "Resume Script"
I have don't know what you mean by "A portal opens" or by "Toggle Window" (Status Area?).
-bd
Instead of changing ti Find mode and pausing while the user enter the criteria, use global fields and do it in browse mode.
Cretae a global field, say "findcriteria." In browse mode the person enters what they want to search for into the global field, then clicks on a button. The buttn run a script that changes to find mode, uses the Set Field step to insert the entry from the global field into the real search field, then performs the find. No pauses or resumes necessary.
