problem with To: field using send mail script step
If I put an email address in the To: field of the send mail script step and then send it via Mail.app OS X 10.3.3, The address doubles itself like this <[email protected]>, <[email protected]>.
If I put: Name <[email protected]> in the To: field, I get the following:
I can't find documentation for this annoying behavior... can anyone else duplicate this?
Dana
Version: v7.x
Platform: Mac OS X Panther
Do you have it set to Send the e-mail to your found set? Or is it only sending it to the current record?
just the current record. So I can loop through the found set and send a customized message to each recipient.
Reed,
I just tried to duplicate your problem with no luck. Hopefully someone else will have some idea to help you out.
Michael
I remember this when I used it years ago. In the end I just entered the naked e-mail address into the field, no names or extras.
  • 3 weeks later...
I'm having the same exact problem as Reed where the email address doubles itself. I'm doing the same thing...have a script that loops through the found set and sends a customized message to each recipient. I'm using OS X 10.3.2 and FMP 6.0 v4.
Kristine
  • 2 weeks later...
I am having this same problem with the Send Mail script step and the Mail application in Mac OS 10.3.3. The To field is incorrectly formatted even if I just put in an address only. The bug appears to be with Mail though, not Filemaker. If I change my default email client to Entourage the script works.
I have tracked down the issue with Mail, and I have found that if the email address appears in Mail's previous recipients list, then the To: field will be correctly formatted. So if you send mail to each recipient through Mail first, subsequent mailings should work.
Dana
  • 5 months later...
Anybody had any luck getting around this (without just using naked e-mail addresses)? It
