FileMaker 2026 Released
Stabiltiy Problem
I am using FMserver on a Windows 2000 network. When I connect using mt Windows xp machine I am getting a database that is not responding. This does not happen on other machines only the Widows XP machine has anyone any ideas? I do not know where to go next I have just reinstalled FM6. I have never had a stability issue with FM before.
FileMaker Version: 6
Platform: Windows XP
Does the database show up in the hosts dialog? Are you using a directory service to control access? What exactly happens when you try to connect to the database?
I solved the problem. The problem is that Filemaker has never given me a problem before and I had to do something that I have not done in a long time. I re-booted my PC. The thing is that I have never done this in two years of Filemaker. Once I did it everything was back to normal.
