printing problem
I've been experiencing the following problem when printing out a 10 page form in FMP 6. The form contains a logo (in this case a .jpeg) file in the header. IF the form is 6 pages or under there is no issue, however if the form is more than 6 pages, pages 7 thru 10 only print part of the header and none of the body. Further, if I change the print quality to a lower quality it works fint. Only problem is that the forms look crapy. This dosent seem to be a printer or computer issue, the problem exists in all the envrionments (Windows) that I've dealt with. Anyone ever run into this type of problem?
Thanks, Ron
This sounds like a printer problem: the printer is running out of memory.
If you print the layout without the image (duplicate the layout then delete the image) does it print OK?
I thought the same thing at first. However If I remove the Logo all 10 pages print fine even with the print quality set at the highest quality.
Then either the logo is corrupt in some way, or the layout + logo is exceeding the printer's memory capacity.
Good question: it'll test the FMP print engine and the printer driver installed in the OS, but be independent of the memory in the printer.
