read-only permission problem
Hello,
In an application that uses 12 FM5pro databases, I'm trying to give someone read-only access, but I get a "no access" message in my layout-screen instead of the records I wanted to show.
All the files are multi-user, and I created for all of them a new password as following :
browse records = checked
edit records = unchecked
delete records = unchecked
create records = unchecked
print records = checked
export records = checked
override data entry warnings = checked
design layouts = unchecked
edit scripts = unchecked
define value lists = unchecked
change password = unchecked
available menu commands: none
This looks fine to me, but it doesn't work.
Is there something I missed?
bart
In fact there is only one file that gives a "no access" error. All the other files don't give any problem.
The password settings for this file are exactly the same as the setting of the other files...
I found it myself : I just had to add the new password I created to the "users" group.
You can change my status to newbie again ;-)
