Simple script not working ....HELP
I hope this is an easy script to fix...
The script:
Go to Layout [Report1]
Print [Restore, No Dialog]
Go to Layout [Main]
The Problem:
It goes to the correct page...but then stops...does not print nor does it go back to the main page. I have tried added freeze window...also I have tried adding enter preview mode...nothing seems to work
Joseph
Joseph:
Turn the print dialog on. If the dialog comes up when you run the script, you know that step is actually being hit. Examine the dialog. Is it set to a valid printer? If you go to the FileMaker Pro options in the print dialog, is it set to print the current record (or records being browsed, depending on your desire)? Open the script in ScriptMaker and set these things to the way you want them, under Specify Print Options... Now what happens?
-Stanley
