FMP 7 Portal Problem
Ummm.. last post got moved or deleted I think..
Anyway, here's the problem.
I had a relational DB set up in FMP6 so that a Notes Database would display the Date and Tiltle of the Related record in a portal in my Main DB. Now, I had a button and script set up so that I could click on the button in the portal and it would open the record in my relational DB. The problem is, I can't edit anything in the related record once I get there. I get "This record is already being edited.. blah blah"
I assume that if it is being edited in the portal, it won't let you in the record, but it wasn't this way in FMP6 any way around this?
Thanks!
D
Figured it out, I had the script set to Open rather than Open Hidden.
Thanks!
