Help with Troi Serial and FM7
Has anyone been able to get the dispatch scripting in the Troi Serial plug-in to work with FM7?
When the plug-in is triggered by received data FM crashes.
  • 4 weeks later...
I just started using the Troi Serial Plugin and FM7 with a dispatch script and it works fine. You might try starting with a simple dispatch script.
