Copy paste problem
Hello...
The following script pastes the contents of 'gname' at the end of the data already in the 'comments' field. However I need to be able to paste the data at the cursor position in the 'comments' field. Any suggestions would be appreciated.
Copy [select, "gname"]
Go to Field ["comments"]
Paste []
thank you.
[email protected]
I recommend using the Set Field command instead of copy and paste. If you want to append the contents of gname to comments, then you would have:
Set field[comments, comments&gname]
If you want to insert gname at the beginning of comments, you would have:
Set field[comments, gname&comments]
Thanks Bob. I'll try that.
best regards...
