Portal Visibility Problem
Whilst it is true that the objects that are contained within a portal are not there on the layout until the data in the join fields match, but - and this is my problem - the user can still click into the portal itself even when it is "invisible". Is there any way of preventing the user from inadvertantly clicking in the area of the screen where the portal will appear (when the join fields match)?
Draw a button inside this portal (background) with same size than your portal and attach an ExitRecord script step to it.
