July 28, 200422 yr I purchased MenuControl from Dacons, Inc. so I could make custom menus in FileMaker. Alas, FileMaker does not accept the steps in the startup script. According to instructions from Dacons, the startup script should have the following steps: Allow User Abort [Off] Set Field ["Result","External("Cont-Set-RegName","-name-")"] Set Field ["Result","Cont-Set-RegCode","-code-")"] (where my name and registration code are substituted in -name- and -code-, respectively). But FileMaker doesn't accept either Set Field statement; it says it's missing an operator. This is my second plug-in (the first being FileBooks, which I finally got working after trading e-mails with Happy Software for several days). So I'm still a newbie with this stuff. Dacons tech support is useless--I think they're just distributors. If you're an expert plug-in wiz, please respond. Copy me directly at [email protected] Thanks.
July 28, 200422 yr Author Thanks to [email protected] for helping me out. The correct startup script is as follows: Allow User Abort [Off] Set Field [file::result; External("Cont-Version","")] Set Field [file::result; External("Cont-Set-RegName","-name-")] Set Field [file::result; External("Cont-Set-RegCode","-code-")] Here, file is the database table name, result is a global text field, and -name- is name and -code- is the registration code. Anyway this now works.
