Script will not work for guest
I have a script that I use to import records from one table to another. When the file is shared by other useres, the script will not work. I have to go back to the host and run the script from there. It's a big pain. Anyone have any ideas as to why, and what I can do to resolve.
hi check your "accounts & priveledges" that scripts are executable
I have the same problem. I ran the import script with full prvileges set and it still didn't work.
Has anyone out there ever run import scripts from a shared database? This has had me stumped for a long time - Thanks in advance. REALLY would appreciate the help
Thanks so much Ender - I can finally move on to a different approach. Thank you, thank you
