installation problem
i've bound a runtime under a Win98 emulator and created an installer with inno setup as i've done many times before.i've tested it on two machines. on the one where i bound it worked fine. on a powerbook running the same emulator the installer unpacked the file ok. on launch i got this error:
The MSVCP60.DLL file is linked to missing export MSVCRT.DLL:_lc_collate_cp.
followd by this box:
Unable to execute file: <filename>.
A device attached to the system is not functioning.
i don't know enough about windows to know what's going on. anyone have a clue?
thanks,
stefan
Hi, Stefan. I've seen this before, but don't remember exactly how i addressed it. confused.gif First, search your computer for msvcrt.dll. If you have it in your system folder, copy it to the runtime's installed directory. I believe that is the fix i used in the past. If that doesn't help, look at Microsoft's KB article about it.
HTH
Jerry
