Clean Up Script help?
I am having a hard time figuring out how to do something which I'm sure is pretty easy (if you know what your doing). I have an table called DesignLineItem and I need to make a script that searches out and deletes all blank records (from the entire table, whether 1 record or 100) , being records which are blank in 2 specific of 5 fields (productmodel_fk & productqty_fk). If it came down to blows, just deleting the records which show no value in the productmodel_fk field would probably do just fine as well. Could someone help me with this? Thanks.!!
One script step: Perform Find will do it specify the field productmodel_fk and use the = then click add. Then choose productqty_fk and use = again and click add again. Then click OK. Run the script.
