Setting access privileges problem
I set up a find page with different global fields for entering search
criteria. I have problems in setting access privileges to users. I
want to restrict users from editing and deleting the records of the
database. But once I removed the privileges of Edit records and Delete
records, users cannot enter search criteria on the find page because
it prompted with an error message of "The field is not modifiable".
How can I set the access privileges in this case?
Upgrade to version 7, which has much more access/privilege control.
The global fields should be accessible in Find mode.
