November 2, 200421 yr Hi All, I just locked myself out of my file I built a Quit script that closes all open files & should ask if the user also wants to close FileMaker. i must have messed-up something. Is it possible that this script sent my file in some sort of loop, bacause now my Starting script (that just displayed a splash screen & went to the Main Menu) opens & closes my file. Is there a way to perform or abort an opening script??? Thanks --Dan
November 2, 200421 yr Author Thanks, but i could not access that option in my menus... I was able to solve my problem by using another file, establishing a file reference to the problem file. Then in the other file i created a script that had a script step that called a script in my problem file. That seemed to stop the problem script running in the problem file!! So i regained access & protected myself by creating a script to HALT all running scripts and made sure it's available on the menu. Just thought i would share my solution in case another person can use it.
