Portal - Scripting Problem
Recently I built a DB using the FileMaker Business Tracker solution as a template. (I'm just at the beginning) but I can't solve a problem using a script on a portal.
This is the situation. On the "Company" layout I have a portal from the "Contact" table that display the name of people working for the company. My intention is to click on the contact name on the portal in order to get more details (phone, mail, email etc).
To do this I imported the script from the FM Business Tracker file and adapted it to my settings.
The Script works fine. The Contact Details windows open but the record displayed is always the first one from the contact list. I'm sure that some parameters are wrong but I can't figure out what due to my inexperience.
Hope someone can give me some suggestions.
Fly
Make sure Go to Related Record [show only related, "yourrelationship] is the first step in your script before Commit Record or any other steps that take focus away from the portal.
Thanks for your reply.
I tried to build a simple script using the Go to Related Record [show only related, "yourrelationship] but in this case the record that the new windows is showing is always the first one on the portal. So if I click on the third name the info for the first name on the portal will show up.
Fly
Check your button dimensions to ensure they are within the first row of the portal.
I did. I tried also to create a tiny button but the result is still the same.
Check that the relationship in the GTRR step is the same as that of the portal. If that's not the problem either, stuff and attach your file for investigation.
Sorry, can't solve it. Here's the file. It's probably a mess ) It's on FMP7
ad_tracker.zip
As I said, GTRR needs to be the first step. You're opening a new window first, so you lose your place on the Company layout and the first related record becomes the default. Instead, use the New window option in the GTRR step.
Got it. Thank you so much for the help.
BTW what do you think about the file. What do u think I can improve.
I've been using FM (2 weeks) but I really love it smile.gif)
Fly
It looks pretty good to me. I would suggest doing away with the Insert and Clear steps and using Set Field instead though.
Insert Current Date [Companies::Notes]
Insert Text [Companies::Notes; " - "]
Insert Current Time [Companies::Notes]
can be changed to
Set Field [Companies::Notes; Companies::Notes & Case( not IsEmpty(Companies::Notes);
This Tech Note:
http://www.filemaker.com/ti/109174.html
Speaks about this problem:
"Go to Related Record [show only related, "yourrelationship]"
The Tech Note suggests that the problem was fixed with 7.0v2
Good Luck.
Garry
