Look up problems with a portal
Hi, I have a portal ten deep. I want to be able to choose a company name from a drop down list, then in the next column have a company contact automatically fill in. The problem is that when I do it for the first record, it changes the contact name for all ten records to that one company. I used to have the user enter a company number and all the corresponding info would fill in, but my boss wanted to make it easier, hence the drop down box idea. Any ideas?
Vandy
Check that the Contact Name field in the portal is a lookup field in the join file rather than the original Contact Name field from Company.
If that's not it, maybe you could post a your problem file or a screenshot of your relationship graph.
