need help with auto-creation of records in portal
Hello,
I posted this in the Scriptmaker forum but only got one reply so thought I would try here...I have written a script that loops through a selection of records and sends out an email (using value of global fields as subject and body). I would like to keep a record of what email was sent to whom so I created a related table (related via an auto-generated, unmodifiable number field) to hold this information. Each time an email is sent I would like to automatically create a new record in the related table and fill it with the sequence number of the current record in the loop, the current date, and the subject of the email. I would then display these records via a portal. I thought I could call New Record/Request within the loop but don't see any way to specify the table. How do I auto-create these portal records?
TIA,
rlbryant
Go to Layout for that table, then create the new record.
Thank you Transpower. I posted the script in the "Scriptmaker" forum where the original post is. I'll end the thread here.
rlbryant
