Pattern Recognition Syntax Problem
Here's what I'm trying to do:
I've got 2 fields, that are the same number of character positions each. (Both are text fields, but could easily be number fields if that would help, since each "character position" is either a 1 or a 0.)
One is a global field (call it "g_fieldA").
The other is a calculation field (call it fieldA).
It's entirely possible for one or both of the fields to have several character positions a 1.
I want a calculation field to determine a "match" based on any of the following criteria:
1. If g_fieldA is all 0's, this is a "match" (This part I've solved.)
2. If g_fieldA exactly matches fieldA (i.e., every character position in each matches the other) (This part I've solved.)
3. If for every character position that has a "1" in g_fieldA, there's a "1" in fieldA, this is a match.
Thus this would be a match:
g_fieldA: 00010
fieldA: 00110
Thus this also would be a match:
g_fieldA: 00010
fieldA: 00111
This too would be a match:
g_fieldA: 00110
fieldA: 00111
But this would not be a match:
g_fieldA: 00110
fieldA: 00010
Nor would this:
g_fieldA: 00111
fieldA: 00110
Any ideas? I assume this can be done with some sort of ("0" or "1") approach for each character position, but everything I've tried fails. He
Give this a try. All fields should be text.
Match? (calculation, text) =
Case(
Length(g_FieldA) <> 5, "No Match",
g_FieldA = "00000", "Match",
Length(FieldA) <> 5, "No Match",
g_FieldA = FieldA, "Match",
PatternCount(g_FieldA, "1") = PatternCount(g_FieldA + FieldA, "2"), "Match",
"No Match")
-bd
[ March 29, 2001: Message edited by: LiveOak ]
I don't think that will catch every case. For example, gFieldA = 01000, and FieldA = 10000 should not be a match if I understand correctly. This is a bitwise masking operation right?
Anyway, I would try this:
gTempResult = (11111 - TextToNum(FieldA)) - TextToNum(gFieldA)
Case ( gTempResult<0,"no match",
PatternCount(NumToText(gTempResult),"9"),"no match",
"match, whoopee")
Just make sure the constant (11111) in the temporary calculation has as many 1's as you have digits in gFieldA and FieldA
"match, whoopee")
I don't think this will work either, since 11111-00001-00001 will result in "no match". I think you want to reverse the "no match" and "match, whoopee" cases! = )
Nice solution!
-Dave
I think you will find it will work. Using this method gFieldA = 01000 and FieldA = 1000 will generate:
pattern count of "1's" for gFieldA = 1
pattery count of "2's" in the sum (gFieldA + FieldA = 11000) is zero and therefore no match
I think you will find that the use of subtraction will not work as is communitive and does not distinguish between which number is in gFieldA and which is in FieldA. A case that doesn't work is both fields equal to 11111, then 11111-11111-11111 = -11111, which tests to no match. Another example gFieldA = 01110 and Field A = 00110, the subtraction gives 9891 for no match. If you reverse the fields gFieldA = 00110 and FieldA = 01110, the subtraction gives 9891, the same, but it should be a match.
-bd
Create12_v2.zip
Ahhh the debate escalates smile.gif" border="0
Right you are LiveOak. The subtraction as I posted it doesn't work, and I had misread your calculation.
Actually the subtraction method can work, the correct method is actually simpler than what I originally showed:
gTempResult = FieldA - gFieldA
the case statement that I gave before remains the same.
So, now there's two methods, unless I did something dumb again.
Someone else sent me the following, which handles all 3 situations!
Case(TextToNum(gfieldA) = 0,"Function Match",
TextToNum(gfieldA) =TextToNum(fieldA),"Function Match",
TextToNum(gfieldA) >TextToNum(fieldA),"No Function Match",
PatternCount(NumToText(Sum(TextToNum(gfieldA), TextToNum(f fieldA))),"2") = PatternCount(NumToText(TextToNum(gfieldA)), "1"),
"Function Match",
"No Function Match")
Many thanks for all the great ideas!
Tom
