script problem - creating related records
Hello everybody,
I'm trying, for a set of records to create, NEW, related ones.
Briefly, I have a SHOPS file (containing 2 fields: shopID and shop name) and a second one MISSION with tasks related with those shops (having as fields missionID, shopID, product, client, aso.)
My objective is to be able to create a new mission for each shop in the current found set. I activate the "make new missions" script from a layout in the Shops file which includes a portal with related fields from the mission table.
My script looks like this:
go to record/request/page [first]
loop
go to portal row [select;last]
set field [mission::product; a value]
set field
set field....
go to record/request/page [next; exit after last]
End loop
So far, so good, even in the example file that I'll attach to the post everything works fine...
But not in the main database, where I want to introduce this feature, the only difference is that on the same layout (where I launch the script) I have one more portal. Anyway, over there, this script is mainly changing existent missions, not adding new ones.
Any idea would be very much appreciated.
Thank you in advance!
Alin
example.zip
Don't use the portal at all for this script. Use auto-create with a separate relationship and a global for missionID. See attached.
shops.zip
