February 8, 200521 yr Wrote some scripts in Applescript to move some import files and another script startup a fp7 file which had an embedded FMP script to do some data imports. Everything worked well for 3-4 days and then poof - nothing. The scripts won't come alive anymore through the FMP Server Scheduler. It may have something to do with permissions changing - but I DID NOT modify anything. The only way the scripts will run - is if I launch them myself. This is a crappy waste of my time - I followed FMP instructions on how to set privilieges for the script folder and the scripts still are quiet. Anybody run into this before?
