Problems with a scrolling portal !
I have portals on a layout for an IWP DB. These hold things such as phone no's etc...
Problem is... Portal shows 5 records... After you have filled 5 records no verticcal scroll bar appears and you can't go to the 6th row... don't get it !
Tried various scripts from a committ button tell it to go to the portal field then last portal row etc but no avail... Any ideas?
Thanks in Advance !
Steve
I was having a similar problem, though it didn't seem to matter how many records were displayed. I tried viewing the database in Firefox instead of Safari and the scroll bar appeared. I think, at least in my case, it was a display problem in Safari.
Good luck.
Hi Steve,
I just had the same problem two weeks ago. You need to download FileMaker Pro 7v3 updater ---- this has solved the scrollbar problems we had (the same exact one you described).
Regards,
Jamie
Thanks, downloaded the update and it works fine !
Other connected problem is this though...
Will put on new post though in case you don't check this
