February 23, 200521 yr Newbies I was wondering if anyone has had problems using the CDML converter? We have a few databases and associated webforms that worked great on FMP 5.5 Unlimited. Recently, we upgraded to Advanced Server 7.2 with the Server and Web Publishing Engine on one machine and IIS 6.0 and the Web Server Module and Web Server on another. The two are separated by a firewall with ports 16016 and 16018 open. I finally got the two to connect across the firewall, and the Web Publishing Administration Console shows XSLT Publishing enabled and active for this database. This database works fine with Instant Web Publishing and the Site Assistant, but I can't get it to function with the converted CDML web page forms. I'm cutting my teeth on the XSTL, but was wondering if anyone had run into the same problem? Thanks for your help. Dave
