IWP problems and HELP!
I'm new to FM Pro 7 but not to Filemaker though most of my experience was a couple years ago
though i did run earlier web enabled dbs with little problem.
So I have a client with 2 FM4 Win databases which easily converted into FMpro7 on a mac 10.3.8.
Everything works fine and dandy from the conversion in FMpro.
The problem is access via a web browser.
3 other users on PCs with XP pro. They only need data entry and perusal.
I enabled IWP down port 591. Databases show up on browsers in the IWP page.
Users either get a password screen where they can't authenticate or a Javascript alert that
too many people are logged in (and no-one is logged in).
When I quit the Databases on the main server it appears that any account trying to login is spawning
a few times thus preventing login (hence the JS error). This is odd because no-one has actually
logged in.
These (appear) to be relatively simple dbs, though i didn't write them. And they weren't ever web enabled before.
I was able to login and out using a "dummy" db i created before i converted these things and tried to
activate them. I don't quite get what's happening here- these are not very sophisticated databases
and I've put up sql and Oracle on linux boxes in less time then I've spent on this. My "simple" solution
has turned into a weird time sink.
Any pointers to whatever it is that's not working would be appreciated.
-squeak
