PROBLEM... pls Help
PROBLEM?
Ugo created excellent calendriers Frnas.fp7. I add few new fields ( calculate: Hebrew Date, Muslim Year, Week) and like to include new Table EVENT with some info about events which I like to have in Calendar layout in extra text format. Create relationship between Calendar and Event, bat that doesn't work !!! Way, were is mistake, what I do wrong? confused.gifblush.giffrown.gif :
Calendar.fp7.zip
My apologies to Cl
I was in a hurry and just wanted to clarify before this post went any further. It's not because I'm not the author that I decided not to look at it.
I will give it a go and see...
This calendar isn't designed for incorporating any events at all. It is just an infinite DatePicker.
You need to use portals for this. There are several techniques around which were discussed lately about them, but it's getting easy with 7's ability to split portals.
He Ugo,
Once again thanks for your attention and explanation, bat formally what I like to do ( have ) in CALENDAR is: How to flagged in shown month (not only today or current day) all possible (eventual) events. That's mean when I open my App - first layout is today and I have portal which show me what I must do on (in) Today or on (in) current date ( with click to any day in month - chosen date/day).
Problem is that this doesn't work as I like (show in calendar all possible Events - obligations for all or any date which have is in Event table equal date/day in Calendar). With my relation only first record from Event table ( in my example it is day of my birthday) will be shown in Calendar (yellow color) all other(New year day & ct.) when I change the month can't be shown. I change date in first record with New year date and then I see only New year but not in February also may birthday.
Idea is that me or anyone can see in month (calendar) that it is some obligations ( events, To-do, Appointments or ... whatever) in some days of month. Then me (he) can
Hi again,
Relationships and Repeating fields....
It's not the best compromise you could get for this task.
Here's just a quick draft with some events set for February, involving a portal rather than a repeating field structure.
The repeaters could be used on the Event side to group all events on one day so that you have a "portal" in a "portal"...and you could even slide from one event to another within a Day, but this isn't implemented here.
Planner.fp7.zip
Hi Ugo once again,
Your app is very nice, but my problem stay. Problem is that I don
