Need help printing PDF's from FileMaker 7
I have a file that contains product info. In each record is a reference to a pdf file that is located in another folder. I need to be able to read through all records for a selected product and print out the corresponding pdf's but I am not sure how to go about doing it. I know I can click print when a pdf is displayed but in this solution, the printing needs to be automatic. Any ideas? Thanks for your help!
  • 1 month later...
You might have a look around the AppleScript forum - I think you would have to call an AppleScript to print the PDF from within an FM script, it sounds similar to generating and renaming PDF files from within FM.
