Help with SQL syntax...
Hi all,
I can't figure the structure/syntax my SQL statement should have...
When i use the ODBC import... my fields are enclosed in `field` sometimes
they are like this: `tblName.fieldName` ...
If i want to update an access 2000 tbl with data from fileMaker
how would I write that??? UPDATE tbl SET fields etc..
with commas or semicolons? with ` or ' or " ??
thanks
I'm not sure that this is directly applicable but maybe it will be useful as a start. I have had success passing a string of the following form to FileMaker (not Access) via ODBC to cause an update of the Clients table.
"UPDATE Clients SET `flag_qb_modified` = 0 WHERE `client_id_number` = 523"
Note the outer double-quotation marks are not part of the string, they are just part of how the string is represented in the source code file. But the inner back-ticks around field names are in the string.
thanks for the tip...
I will try that
YEAH!!! found a syntax that works!!
"UPDATE tblTempInbox SET DispoStatus = '" &Trim (IncomingNouveauMail::t_StatutDispo) & "' WHERE MemberID = '" & Trim(IncomingNouveauMail::t_MembreID) &"'"
I had to use the trim function...for some reason i kept getting a leading space in all my fields so nothing would match & update!
