Number range indicates text need help
Hello
I have a field with is called priority code. "PC" I have another calculation field which is called "TEXTCODE"
the numbers are sequential from 1 to 7 and then they are ranges like 13-15
I have statements to be calculated to the field "TEXTCODE" and I need help writing them because they are lot.
The table is this
1= "RED"
2= "GREEN"
but
7-10 = "BLUE"
So if the user enters in 8 it would be " Blue " in the text field
I have to write this formula and i need help
Dave
Using the examples you provided one way would be a Case statement.
TEXTCODE = Case(
PC = 1; "RED";
PC = 2; "GREEN";
PC > 6 and PC < 11; "Blue")
Another way would be to create a PC table with two fields PC and TEXTCODE. Record one PC =1, TEXTCODE = RED, record two PC = 2, TEXTCODE = GREEN etc. Then relate this new PC table to your main table by PC = PC, TEXTCODE in the main table would be a calcualtion = PC::PC.
This is a good place for the case statement.
Something like this:
Case (
PC >= lowest number in highest range; Color for highest range;
PC >= lowest number in next highest range; Color for next highest range;
and so on
PC >= 7; "Blue";
PC = 6; Color for 6
and so on
PC = 2; "Green";
PC = 1; "Red" )
