adjust window[resize to fit] not working right
seems like as it hides the status area, it doesn't adjust properly so that i don't see the whole report.
I would think that if that is happening you are not using 96dpi fonts for your screen (if so, you'd know about it -- you'd have to have done it).
Could you maximize the window instead?
i am using 96dpi fonts. still not working so i did end up adjusting the layouts and maximizing the windows - but only for the scripts where the resize to fit doesn't work.
thanks, rob.
What do you expect it to do, when you ask the window to resize to fit?
You'd probably be better off speicifying the window size you want.
i expect it to show the whole report (it's not) and not necessarily the whole window. shouldn't it?
i've maximized it now and yes, i might have to specify the window size for a better look.
Well, what exactly is the "whole report"?
Many reports, like thouse usssing summaries, only appear correctly in Preview mode.
If you are in Preview mode you'll see only the first page. In browse mopde you'll see the current layout.
i meant the whole report on the current/first page. yes, it is in preview mode.
on the current table, i created 2 buttons w/ scripts. seems this 2nd button retains the size of the window of the other button script when it previews the report. but not vice-versa. such that the other script shows the report just fine (slightly smaller window) but this script doesn't reveal the whole report on the page since its report layout is a bit wider than the other.
Resize to fit will fit your screen, not the report...
