FM7Pro import problem: no error msgs
I have created a new FMPro7 db that is an enhanced version of an existing FMPro7 db. The fields have been renamed and rearranged in the new db.
I am trying to migrate the old db records over to the new db using the export/import feature.
In the old db I do a File>>Export (have tried to a .csv, fm7).
Then in the new db I do a File>>Import using that exported file data.
As I set the mappings in the new db and click to start the process, I see that it goes thru the full set of imprted records and then tells me that all failed to get imported but does not tell me why.
Can someone shed some light as to how I can find what the Import process did not like about the imported records? The msg dialog box only says there was a problem it doesn't say what the problem was.
Thanks.
