fmxslt:send_email($email_info, $email_body1)
I have been unsuccessful in the process of making some parts of the text bold or colored.
Did anyone used or with this function?
The desired fields are sent correctly with the fmxslt:send_email function.
I just need to do some cosmetics on the text.
Thanks for reading my post,
Bogdan
Hmmm,
Does anyone know if this is possible?
I am more interested in making some fields in the email bold.
Thanks for reading this,
Bogdan
I can't say much without any code example from you. Just some questions:
- did you try also with fmxslt:send_email(String smtpFields, String xsltFile, Node xml, boolean includeImages)? You can specify an additional xsltFile that generates your e-mail body
- did you try to encode the e-mail body with fmxslt:html_encode(String value)?
- did you follow the MTHML standard by IETF?
