August 27, 200520 yr Newbies Hi, first let me tell my specs imac g4 800mhz filemaker 7.0v3 mac os x 10.3.9 i'm having the following printing problem: i'm trying to print to different printers and filemaker crashes, i've used the change printer plugin and the first print goes ok, but when i change to another printer and click print fm7 crashes, the thing is that with the fmbuttler plugin it crashes too when i do the same stuff, so what i did was ran filemaker on another partition i have that was clean installed with os 10.3.8 and then installed filemaker 7.0v1 and the same thing. i tried to make some simple scripts to test this, that basically were print setup and print for both of my printers and when i was on the second script fm crashes. any ideas on this issue? thx and best regards roberto Edited August 27, 200520 yr by Guest
August 29, 200520 yr Have you tried running under another OS X user instead of another partition. If it works than I bet a plist/pref file has become corrupted. I would quit filemaker, delete the file com.filemaker.filemakerpro.plist and com.filemaker.pro7D.plist and possibly some other preference files as well as any plist or pref files that fmbutler may have made, doubtful that a plugin would have them though, and try again.
