Problem with HP printer and FM 7
This may be a little off topic...excuse me if it is. I have a locally attached HP Laserject 1012 printer. When I print from within FM, either using the print command on the menu bar or within a script - my printer does not automatically print. The printer acts as if it is having a problem grabbing the paper and produces an error stating I have to manually feed paper to it. If I press the reset button on the printer it prints the document just fine. I thought it was a problem with the printer but I tested it with other programs and I have no problems. Therefore it is not the printer but something within FM that is causing the problem. Any ideas???
check your print setup. Usually when this problem occurs is when the print setup is not correct for a layout.
When I first read your response I thought you were crazy. But I checked anyways. Somehow the printer setup was set to "manual feed". I never would have noticed this! Thanks a lot.
