Relationship help needed...Before I go mad!
I'm trying to set-up a mileages db and I figured that this might be best accomplished with a Portal...
The objective is to automate mileage entry in a trip-itinerary
Table 1 - Mileages
Field 1 - city1 [text] // from
Field 2 - city2 [text] // to
Field 3 - miles [number]
Field 3 - city_city [calc text]
(city1 & " to " & city2 & " " miles & " miles")
Table 2 - Itinerary
Field 1 - city [text] //insert city for match
Portal - city_city
The relationship is made between Field 1 = Field 1
This works...But I can't get to the next step...
By way of example...
San Francisco - LA
San Francisco - Seattle
LA - Seattle
In this example the portal shows both SF mileages but if you look for a match based on LA you only get LA-Seattle and if you search for Seattle nothing appears.
So the next relationship step ought to be Field 1 = Field 1 and Field 1 = Field 2
I've spent hours toying with this and I'm now officially snow-blind!
Offers of directional (!) guidance would be much appreciated.
Tim
Try creating a text calculation in the Mileages table =
City1 & ¶ & City2
and match the city in the Itinerary tabe to this field.
Misunderstood the problem
Thank you!
Such a simple solution - I would never have thought of that, which is worrying!
I've now expanded this enormously and having spent all day on it, I can guarantee that the next problem is fast approaching!
Tim
