November 10, 200520 yr I have 200 records. Each record has different values for example. DC # Store# Style# 10 27 107 10 27 107 10 27 107 10 27 101 10 27 101 10 27 101 10 28 107 10 28 107 10 28 107 10 28 101 10 28 101 10 28 101 10 29 107 10 29 107 10 29 107 10 29 101 10 29 101 10 29 101 10 74 107 10 74 107 10 74 107 10 74 101 10 74 101 10 74 101 10 81 107 10 81 107 10 81 107 I want to create a report using a scrip so that i can print all stores at once, but having all records with store "27" on 1 page, store "28" on another page and so on. Any Ideas. Thank you
November 10, 200520 yr Create a columnar/list report with grouped data using FileMaker report assistant. In the "Organize records by category" dialog box of the report assistant, select the field "Store". When you finish designing the report layout, in layout mode select the part definition of the summary part and select the check box to Page Break after every 1 occurance.
