XP and Pro 7 import problem
I have a FM 7 solution with multiple files. When I try importing a found set into file1.fp7 from file2.fp7, it imports the entire record set, not the found set. I know this was suppose to be fixed with version 3 and it was when I did it on Win2000 but it doesn't work with XP. Any idea why it works on Win2000 and not XP?
I also have Windows XP and I haven't had any problems. I have a script that imports only found set from a related file on a daily basis.
If you could attach the file, we can look at it and see what could be the problem.
I know my solution works. The script works on Win2000 and I tried it today on a different XP machine and the script works. So the question is why does the script only work on 1 of the XP machines.
Vs. 7 brought a change on import.
In prior versions, if a file was closed, it would only import the current found set from the closed file. In vs. 7/8, ALL records from a closed file are imported (because no window is displayed). A found set will only be imported if the file is open (and a window is displayed).
I've performed daily imports for the past year and haven't noticed any problems or differences between Win2000 or XP - and we used 7.0v1 all that time.
LaRetta :wink2:
And the answer was...
go into the script and click Specify data source
clear anything in the File Path
add the file path again
Still don't know why that worked. I am guessing this problem had something to the with the file extensions been visible.
