Using related fields or copied fields with synchronization issues?
I'm sure questions like this have been discussed/answered before. If there are some previous posts I should check out please point me to those links instead. I was in doubt putting this question here or in the 'Define Fields' Forum; if I entered it wrong please move it for me.
I'll describe the issue with 2 of the files/tables I'm using, there are actually more files in use for this database system but the same principle would apply. The 2 files are COMPANIES and CONTACTS, COMPANIES has a one-to-many relationship to CONTACTS
I started, as I think it should be done, by storing all unique information in one place only so e.g. the 'Company_name' field exists only in the COMPANIES file.
However after thousands of contacts had been created performance for finds on e.g. company name and contact-city, from within the contact-file, decreased so much that I had to add a field 'Copy_Company_Name' in the CONTACT file. Changes to the Company name are now only done scripted because it needs to update the COMPANIES-Company name and all CONTACTS-Copy_Company names etc. I've applied this technique for several fields that are frequently used in finds.
Is there maybe a better approach for this? The more files and relationships are added the more complex the synchronization of 'copied' fields becomes. Is there a way to e.g. trigger relookups of fields or to somehow store calculated fields that involve relationships so they can be indexed for fast searches?
Many thanks for any advice.
THis sounds like an architecture issue. A find on a related field will be somewhat slower than one on an indexed one. But your results sound abnormal.
Try finding on the company in the company file, then perform a go to related records script step for records in contacts.
HTH
Old Advance Man
Thanks for your reply Steven, let me try to explain my situation again with a different example.
- I have a file 'Contacts' with key field Contact_ID
- I have a file 'Quotations' with it's own unique Quote_ID and an auto-entered field rContact_ID.
- Every contact can have multiple quotations
In the 'Quotations' file I use a relationship on contact-ID to lookup fields like Contacts::SalesRep etc.
A frequently performed task for a salesrep would be to view his/her forecast which requires a (scripted) find on certain date and progress fields and the Contacts::SalesRep field. A find like this typically takes around 20 seconds. As soon as I change the Contacts::SalesRep field into a stored/indexed Quotation_SalesRep field within the Quotation file, the same find completes in less than 5 seconds. (Field Contacts::SalesRep field is also indexed)
Simulating this on a hi-cpu stand alone client shows that a major part of this issue is caused by the rather slow hosting server. This doesn't however change the fact that storing frequently used semi-static fields in related files rather then looking them up all the time takes away a lot of overhead on the hosting server. For me the performance increase outweighs the trouble of keeping the master and child files synchronized. The few times a contact salesrep changes so all child quotation-salesreps have to be updated (happens only a few times a week) a scripted update changes the few related child's in a second. Major updates for complete sales-territories reassignments require scripted updates of multiple files anyway.
So far so good, the above principle works fine for multiple occasions where I had performance issues.
To my question: Right now I update the 'copied' instances of fields in related files by going to a (hidden) layout with a portal for each involved relationship, by 'walking' through all portal rows I update/synchronize the changes. Is there a better approach for this to somehow force related records to re-lookup values on changes to the 'master' field.
Thanks for your time and help,
Andries
