January 12, 200620 yr Newbies Sorry for the terrible subject line. I'm totally new to Filemaker, so bear with me if the terminology is a little incorrect. I'm having a great deal of difficulty figuring out the scripting aspect of the program. Here's what I want to do. I am making a database of plants. I created a layout with a number of fields, some text, the rest containers for images. I have 16 image fields, image1, image2, and so on. I want to display one image at a time for each record and have buttons to loop through the images so you can see them in detail. Every record doesn't have the same number of pictures. The way I am approaching this now is to have 17 different layouts, which is ridiculous because I can't easily edit them. Layout17 has all the text information on the left side of an 11 x 17 sheet with a grid of thumbnails on the right. If you click on image5, for example, it goes to layout5, which has only one image on the right side. What I want to do instead, with scripting, is have forward and back buttons and a top button that takes you to the thumbnails, so I would only need 2 layouts. But I can't figure out how to define a variable and then use it to determine which field to display. The scripting language doesn't seem very logical but what do I know. I don't even know if you can dynamically change what a layout item refers to.... I would appreciate any clarification. Thanks! I am using version 8. The databse itself isn't important really. Just assume that I have 3 fields, all container fields that I am using to display jpeg images. These are image1, image2, and image3. The main problem I'm having is a script that does this: • checks to see what field is currently referenced in the layout, say it's image1 for now • stores "1" in a variable, x • y=x+1 • takes the value for y, converts it to text and adds it to "image" • checks if the currently displayed record has an entry in imageY • if it does, change the reference of the field to imageY • if not, change it to image1 this is for a next image button. it checks if there is an additional image, because there could be 1, 2, or 3 images. If you're on image2, and there's no image3, it goes back to image1. maybe there is an easier way to do this?
January 13, 200620 yr hi, just a thought, but what about putting your images into a portal instead? cheers, jd.
January 18, 200620 yr Hi, I'm trying to do the image trick you are and am having all the same problems. Check out the post "Mutiple images in one container" topic #173100. Fenton has given some great tips and a demo file. It might help you as well. Fenton has a second table with that contain the images which are cross-refeneced (and related) to your main table. You then bring the images that are related to the main record viewed through a portal (as JD reecommended). It's still tricky but it might do what you want.
