Input Mask with 8Pro (not Advanced)?
Is there any way to create an input mask so that the person doing data entry doesn't need to put in the parentheses or hyphens in a phone number?
I saw that it can be done with Custom Functions, but there's no way I can justify FM8 Advanced.
You don't need a custom function for this, unless you're doing something sophisticated, like letting the user specify the format. Just define the field to auto-enter the formula, replacing existing value. See here for a possible formula.
Thank you SO much! I'm a total newbie. Once upon a time I was at least a novice with Access, but haven't used database software for over 6 years.
