March 17, 200620 yr I've tried to upgrade from FM v7.0.1 to v7.0.3 on my Windows 2000 Server using the FM upgrade package but I keep getting an error message stating that a DLL is missing and the upgrade cannot continue. I've tried on two different servers withour luck. Anybody else had this problem?
March 17, 200620 yr Are you talking about upgrading filemaker pro or filemaker server... Either way, have you tried uninstalling, followed by a fresh install prior to the upgrade?
March 17, 200620 yr Author Hi, Upgrading FileMaker Pro. Yes I have tried uninstalling and installing from fresh before trying to upgrade again. Wierd!
March 17, 200620 yr I wonder if it has to do with the fact that you're running it on a server OS, and FMP client doesn't list 2000 server as a supported OS. I do have FMP and FMPA 8v1 installed on a 2003 server box at work. I haven't tried to update them to 8v2 as I don't use them often... it was only a test to see if they would install and run.
