Intel iMac and FM, a problem?
I have a 7 client LAN running FM5.5 and the clients are FM6. All the machines are OSX Tiger 10.4.4 or higher and 1 is an intel iMac running 10.4.6 The Intel iMac has been getting disconnected from the server for no apparent reason and I'm wondering if there is a compatability problem. Anyone have any ideas?
Mike
It seems to be happening 2 or 3 times a day. Sometimes in the same 15 minute time span.
Hard wired or wireless? Either way, it might be the network card.
~Genx
Is the iMac using enrgy saver preferences?
If it's set to go to sleep then all network connections will be lost.
I have FM5/5.5 and 6 clients with 5.5 server and ALL operating systems (98, XP, OS9 - 10.4.6) - no problems.
  • 1 month later...
help! Ive got FMP 5 and a new intel macbook running tiger. it wont even open , all of my databases are in FMP
Is there anything i can do?
Since the Intel macs can't run Classic, FM5 and below won't work. You'll need to upgrade to a newer version of FileMaker.
