Weird Merge Field Problem
I have an Invoice layout, which works fine in browse mode, all info correct, etc. The Invoice number and customer name appear as merge fields in the header and again in the footer (same merge fields). When I switch to preview mode, The header is correct, but the footer now shows data from a different record. What did I do wrong? This is dang frustrating.
Try stretching your subsummary / body field so that it only fits one per page (or turn on page break after each occurance). It's likely picking up the last record on the page... though im not sure why your storing data in the footer.
~Genx
