Breaking Parts
:P
I have a layout with
a Header,
a Body, (consisting of one line horizontally)
a Sub-summary (trailing),
another Sub-summary (trailing),
and a Trailing Grand Summary.
In the first (highest) Sub-summary I have a Summary field and a Date field under which there is a .5 pt. rule above a 1 pt. rule.
If there is an amount of records sorted that would continue on the next page, I would like the report to break after the 1 pt. rule. In other words the groups of sorted records (in this case by date) should not go across two pages.
How does one accomplish this? Any help will appreciated.
Thanks.
Your only choice is not allow the part to break across the page break. If you have multiple records you want to keep grouped together, there's not much you can do. You can prevent a record from being split across multiple pages with the feature mentioned above but you can keep groups of records on the same page.
