Filemaker 6 - Need help joining two fields! Please help
Hi everyone,
I have a FM database with around 90,000 entries. I want to add a new field and then combine it with another. For example:
Now I have:
John Doe
I want to add to all 90,000 records:
"Mr."
So now I would have:
"Mr. John Doe"
How would I easily go about doing this? So far I am able to create the new column and I created a script to loop through and add "Mr." to each field. Now I just need to find a way to merge it with the other column. I tried everything I can think of.
Thanks in advance for any help you may be able to offer.
Thanks!
Hi PromoPunch,
What I would do is add 1 regular text field and make sure it appears on your layout. Lets call it Temp_field.
Second stage is to make sure you are in browse mode and the temp field is highlighted and then go to the top menu
Records -> Replace Field Contents -> Replace with calculated Result.
In the calculation if you type in
"Mr. " & YourFieldName and then click on OK and Replace.
That should do it.
Please make a backup before you do a replace!
Hope that helps
