Insert Picture problem: No dialog!
I'm having a problem with the Insert Picture command. The problem is there is no dialog box that appears to choose the image file. I've tried also with Insert File and... nada!
I used Get (LastError) and it only returns the number 3.
Can someone help me here?
Have you set up a button attached to a simple script to do this? If so, what are your script steps. All you need is:
Go to Field(::Picturefield)
Insert Picture[] /* leave store only as a reference blank. If you click on "Specify" you can specify the folder you wish to open.
HTH
I found the source of my problem. The container was a calculated field from a text field. That's why the Insert Picture was not working.
