FileMaker 2026 Released
send AppleScript commands to FileMaker Pro on remote system
I am writing a script to tell a remote machine running FileMaker Pro to run a FileMaker script.
set remMachine to "eppc://" & userName & ":" & pasword & "@" & ipNumber
tell application "FileMaker Pro" --of machine remMachine
   do script FileMaker script "Some-Script"
end tell
Note that of machine remMachine is commented out.  If I uncomment out that part of the command I get an error when I try to compile the script...
Sytax Error:  Expected end of line but found “script”.
How do I make this script work?   Thank you.
Here's what more playing today has shown me:
While the code I previously posted fails as I described, this version works...
tell application "FileMaker Pro" of machine "eppc://USER:[email protected]"
end tell
Encouraging, except that 'd rather the IP address to be calculated and not hard-coded.
For now I think I will hard-code the possible IP addresses and then run the version based on some if-then stuff. But I'd like to know why my original idea is broke. It is probably simple problem.
