January 3, 200719 yr I am sure the solution is simple but couldn’t figure it out. How to go to invoice# 1827 in an invoice table?. I tried GoTo record script By Cal with Invoice::InvID but did not work. It seems that FM uses its own numbering.
January 3, 200719 yr You'd have to run a find.. Go To Record is simply a device to go to a particular record in the current found set, for example if you have 1000 records in the current found set, Go To Record[500] will take you to record number 500 of 1000...
