Need Help: Get Path from Container File without Filename
Hello everyone I am a novice filemaker user, and am putting together a DB that allows me to select a file and place the reference in a container field, then I have a calculation field that tells me the file path, what I need is a way to get the path minus the filename. any ideas?
I have got the path formatted almost completed to what I want except for the filename always appearing and since the filename will always change and there is no pattern I don't know how to just have the path to the folder containing the file.
Thanks, would greatly appreciate anyones help
See if this helps.
thanks that worked great, still don't understand but I will figure it out,
